SD Maid PRO - System Cleaning Tool v0.8.5 (+ Unlocker)
Requirements: Rooted Android 1.6+
Overview: A maid for your android, to regain precious memory and keep it clean & tidy.
Apps you have already deleted sometimes leave data behind and the system creates logs, crash reports and debug files you don't really need. Especially the market often leaves temporary files of downloaded apps behind.
Why not get a maid to clean it all up? SD maid will help you keep your device neat, clean and tidy for you!
Choose a tab, press refresh and then either click a single item to delete or press the clean all button.
The corpse finders search your device for dormant directories and compare those to the list of installed applications.
The system cleaner scans the devices known directories with unnecessary files.
What's in this version v0.8.2:
+ Changed some routines to behave more expected for the user
+ Changed menu layout
+ Moved 'Contact darken' from news to menu ( to many empty mails from random users...)
+ Added internal changelog for people (especially Eric) who can't find it on market sites or XDA
+ Removed extra internal class for samsung corpse finder, uses the android corpse finders class with different paths now, which is much more robust.
+ Changed some toast message to give further information about errors
More info:
Download Instructions:Code:https://market.android.com/details?id=eu.thedarken.sdm&feature=search_result
http://www.MegaShare.com/3229632
Mirror(s):
http://www.filesonic.com/file/870722871
http://www.duckload.com/dl/1Icr2
