Page 2 of 12 FirstFirst 12345 ... LastLast
Results 11 to 20 of 115
Thread: Gameloft SD Cache Extractor v2.1 By Djeman [LINKS UPDATED on 26.01.13]
    El Salvador
    hTC HD2. Droid Incredible. Galaxy Tab
    Android 2.3.3 Gingerbread
    Default Re: Gameloft SD Cache Extractor v1.04 By Djeman
    When I extracted the files from Dungeon Hunter 2 (ATC), only show me the sd files folder, there is not a folder "files" to copy /data/data/com.gameloft.android.ANMP.GloftSGHP.ML... Don't know why.
    Coder
    Oct 2010
    France
    Motorola Atrix
    Because for nova 2, dungeon hunter 2 and maybe others the info file is in the apk. If you open the apk game with winrar in /res/raw there are 3 info files packatx.info, packpvrt.info and packdtx.info.
    El Salvador
    Quote Originally Posted by djeman View Post
    So nothing we can do... or copy this 3 files that you said to /data/data/com.gameloft.android.ANMP.GloftSGHP.ML or not?.
    May 2011
    Indonesse
    HTC HD2
    try use this tool to unpacking file for asphalt 5 version 3.4.1, but get error/not succesfull..
    how to make this tool work with asphalt 5 especially asphalt 5 3.4.1,sorry for my bad englaish
    btw, is that mean place for /data/data/com.gameloft.android.ANMP.XXXX.ML for gameloft files is sdcard//data/data/com.gameloft.android.ANMP.XXXX.ML..
    thank you
    Last edited by anggaARTZ; May 3rd, 2011 at 04:09 AM. Reason: place for /data/data/com.gameloft.android.ANMP.XXXX.ML
    May 2011
    Bulgaria
    Acer Liquid
    Avatar 3.0.3 is a old game, where have you find this link ? with apktool ? ^^
    Well I found it in a pack ment to work for LG Optimus 2x, cause I needed tegra 2 compatible version. The pack is from here:
    http://www.mobilephonetalk.com/showt...mus-2x-Star%29
    May 2011
    Dubai
    R800i
    can you explain more in details about how to copy to data/data because i created folder and name it "data" in my sd. but the game :"spiderman" keep asking for wifi connection.
    p.s i have xperia play.
    May 2011
    Dubai
    R800i
    i found out how to copy using root explorer, but still the name "com.gameloft.android.ANMP.Spiderman.ML" wasn't correct.
    how should i know the corrent name to any game.
    Inside data folder i saw games like uno "com.gameloft.android.GAND.GloftUNO.ML" but with a game like nova 2 "com.gameloft.android.TBFV.GloftN2HP.ML".
    so what is the system to name each game and what is the full name for spiderman game.
    May 2011
    Dubai
    R800i
    I figure it out the name of the game by using root explorer again. going to data/app you will see the full name folder.
    So what i did really is naming spiderman game "com.gameloft.android.GAND.GloftSMHP.ML" and inside it files folder.
    After i past the game in data/data, other folders were created (cache, databases lib and shared_prefs floders) beside the folder with the name "files"
    but the problem now, every time i press the on the game, it shows me that the game stopped unexpectedly (force close). i reboot once but it did not fix the problem.
    Coder
    Oct 2010
    France
    Motorola Atrix
    Euh i'm sorry but i don't understand all ^^
    So you have installed spiderman, unpacked data with my tool, put folder "files" in /data/data/com.gameloft.android.GAND.GloftSMHP.ML and all sdfiles in /sdcard/gameloft/games/GloftSMHP. After when you launch the game it don't work, it's that ?
    Hungary
    Lg Optimus One
    Ice CyanCream Sandwich Love v6.1
    Thank you djeman!
    With Fast Five works fine your app!
    But example,with Sandstorm I got error,when I tried to unpack..
    sorry for my English..:/
