Page 3 of 12 FirstFirst 123456 ... LastLast
Results 21 to 30 of 115
Thread: Gameloft SD Cache Extractor v2.1 By Djeman [LINKS UPDATED on 26.01.13]
  1. #21
    May 2011
    Venezuela
    Motorola Milestone
    Default Re: Gameloft SD Cache Extractor v1.04 By Djeman
    Fail in gangstar 2 3.1.6 result says error and i have only folder "files" and is only a file inside named "pack.info". maybe if we found the way to extract this file and we can manually paste in folder created by game in sd/gameloft/games/xxxx
  2. #22
    Coder
    Oct 2010
    France
    Motorola Atrix
    My tools works only on new system of gameloft. If there have not a file "data.txt" in the apk, it's a old.
    On older apks info file is not easily accessible, it is in the java code.
  3. #23
    Coder
    Oct 2010
    France
    Motorola Atrix
    New version of my tool to unpack files on the new games of android market :
    v1.0.5 : http://www.multiupload.com/O6KKIEJZ0H
    For to get the full link, see in data.txt for the begin of the link :
    http://dl.gameloft.com/partners/androidmarket/d.php
    Template for full link, model and device infos are in /system/build.prop (ro.model and ro.device) :
    http://dl.gameloft.com/partners/androidmarket/d.php?model=MODEL&device=DEVICE&product=GAME_ID
    So a example for asphalt6 on htc desire hd :
    http://dl.gameloft.com/partners/androidmarket/d.php?model=Desire HD&device=ace&product=1102
  4. #24
    Sep 2010
    google
    Android
    Game_ID ?
  5. #25
    May 2011
    Argentina
    Motorola B525 (Defy)
    Cyanomodgen7 beta 6
    Default Re: Gameloft SD Cache Extractor v1.05 By Djeman
    Hello, my name is Alan, I'm from Argentina, and new to this community.
    I tell them I'm having some problems. I downloaded GLZip v.1.0.5 by Djeman, I opened the file data.txt, I downloaded the. zip concerned, all good up there.
    But in several applications (like ModernCombat2 or Asphalt6) I went to the press "Unpack" the. zip, the result of the action failed. Then I open the. zip file and I get "file corrupted"
    Why might that be? Why the server by Gameloft is damaged or was damaged in the middle of the download?
    And how fix this problem?
    I have a Motorola Defy (MB525, with Beta6 of CM7). I know appreciate respond. Thank you very much in advance.
  6. #26
    May 2011
    Argentina
    Cyanomodgen7 beta 6
    DJEMAN you say: "So a example for asphalt6 on htc desire hd - Code:
    http://dl.gameloft.com/partners/andr...p?model=Desire HD&device=ace&product=1102"
    Now, ... the same example for asphalt 6 on Defy?
    Thank you.
  7. #27
    May 2011
    Argentina
    Cyanomodgen7 beta 6
    - please delete this comment.
  8. #28
    May 2011
    Argentina
    Samsung Omnia 2
    Unknown
    Hi, i open the program, i select zip downloaded from Gameloft and say error. I try with many games from GL for example: Fishing Kings and dont works, i try with 1.05 version.
  9. #29
    daica's Avatar
    May 2011
    Tokyo
    HD2, One X
    for bookmarking
    thanks
  10. #30
    Coder
    Oct 2010
    France
    Motorola Atrix
    v1.0.6, works on .czip:
    http://www.multiupload.com/2V3OY7TNUV
