Step 11
Primary items colour settings of the calendar. The colour of 'Column Separator Lines' is the line of the standby mode on the idle background
Step 11
Step 12
Secondary items colour settings
Step 13
Colours of the popup window items
Step 14
Calendar 'View Items' colour
Step 15
Colour of 'Setting Option Items'
Step 16
Colour of 'Setting Option Highlighted Items'
Step 17
Colour of 'Cut\Copy\Paste Highlight'
Step 18
Colour of 'Others'
Step 19
If you want to use the part of the background image for the status area, then is nothing to edit, or you use images in the correct size per drag and drop. If you want to use navibars then change them also per drag and drop. If you want to use different images for the idle and main background, then make a right-click on the image in the small preview under the big preview window, then click on edit/ animate. In the new window go into the properties window -> new layer, then -> 'clear' the first layer.
Step 20
Changing Icons. To change the icons use png files in the correct size (would shown in the properties window). Best solution are svg icon, because they looks on all screensizes nice.
