Page 3 of 12 FirstFirst 123456 ... LastLast
Results 21 to 30 of 119
Thread: Tutorials For Theme Maker
  1. #21
    [Font Master]
    STalk Logo Contributor
    WannaBe Theme Maker
    chungviet's Avatar
    Aug 2009
    Ho Chi Minh, Vietnam
    Samsung Galaxy S2 T-Mobile
    Default Re: Tutorials For Theme Maker
    Step 21
    Editing of the 'List Highlights'. You have two options:
    --Use a new image in a size as needed
    --Change the colour as shown
  2. #22
    [Font Master]
    WannaBe Theme Maker
    chungviet's Avatar
    Aug 2009
    Step 22
    Editing of the 'Grid Highlights'. It's the same way as with the 'List Highlights'
  3. #23
    [Font Master]
    WannaBe Theme Maker
    chungviet's Avatar
    Aug 2009
    Step 23
    Editing of the 'Input Highlight'. Also the same as with the 'List Highlights'.
  4. #24
    [Font Master]
    WannaBe Theme Maker
    chungviet's Avatar
    Aug 2009
    Step 24
    Editing of the 'Popup Windows'
  5. #25
    [Font Master]
    WannaBe Theme Maker
    chungviet's Avatar
    Aug 2009
    Step 25
    Editing of thew 'Call Handling Windows'
  6. #26
    [Font Master]
    WannaBe Theme Maker
    chungviet's Avatar
    Aug 2009
    Step 26
    Editing of the 'Indicators'
  7. #27
    [Font Master]
    WannaBe Theme Maker
    chungviet's Avatar
    Aug 2009
    Step 27
    Scrollbars and Lines
  8. #28
    [Font Master]
    WannaBe Theme Maker
    chungviet's Avatar
    Aug 2009
    Step 28
    Analogue Clock and Hands
    The easiest way to have a good result is to use one of the default clocks which came with carbide. You can use them per copy and paste if you open one of the default themes. If the new clock would shown in your theme, then take a look in the colour properties window and play a bit with colours. You will see that the default clock looks complete new.
    If you have a svg editor, then open the default clock per right click and use it as sample for a new clock.
    You can also create a png clock with your bitmap editor, shown as here in the preview, but then is also a mask needed. The clockhands could be edited to change the colour or to create new as svg image.
  9. #29
    [Font Master]
    WannaBe Theme Maker
    chungviet's Avatar
    Aug 2009
    Step 29
    Pinboard
    That what a written on the preview isn't complete right, because you can make a rightclick on the image in the properties window on singlepiece/ 9piece, in the small popup window which would shown click on 'No' and you can use one image. You can also make rightclick to open the frame in a svg editor, make the layer hidden and save. No is the frame not shown and you see the background image from the menu background.
    The newest mobiles don't have these 'Pinboard'.
  10. #30
    [Font Master]
    WannaBe Theme Maker
    chungviet's Avatar
    Aug 2009
    Step 30
    Calendar
