Results 1 to 9 of 9
Thread: Window Vista/7 Aero Effects Problem
    Danial's Avatar
    Nov 2009
    Karachi, Pakistan
    Nokia E52,5730 XM, N97, N8, iPhone 3G, 4, 4S HTC Sensaion XL, Evo 3D
    054.003 & 5.21
    Hi Guys... I am having a problem... After Installing Window Vista and Window 7 Aero Effects And Window trasparency is'nt working I updated All the display drivers but the problem still exist I face an error in which it says My Display driver doesn't support Aero Effects..Can someone plss help me...
    IF YOU GUYS LIKE MY POSTING PLS PUSH REP++ & THANKS
    TheRemco's Avatar
    Oct 2010
    1+1=2
    Samsung Galaxy S3
    4.0.4 Ice Cream Sandwich (Stock)
    Default Re: Window Vista/7 Aero Effects Problem
    did you updated your Graphic Driver, or your videocard?
    that may be your solution
    Danial's Avatar
    Nov 2009
    Karachi, Pakistan
    054.003 & 5.21
    yes bro i updated the driver but problem still exist
    TheRemco's Avatar
    Oct 2010
    1+1=2
    Samsung Galaxy S3
    could u post your computer specs so i can find you a solution?
    Danial's Avatar
    Nov 2009
    Karachi, Pakistan
    054.003 & 5.21
    Thanks Bro. but I searched alot on the internet and found that my video card doesn't support aero... so i m now using trans bar for transparency...
    TheRemco's Avatar
    Oct 2010
    1+1=2
    Samsung Galaxy S3
    Np bro,
    but look,
    my sister has an Asus pc, with originally win xp.
    yesterday, i put vista on it, which runs perfectly with Aero effects.
    from vista, i updated to win 7, but then the problem came:
    aero effects didnt work and internet either.
    so i removed win 7 and deleted xp, so she can go on her pc with vista.
    Did you upgraded from xp to vista? or from vista to 7?
    Danial's Avatar
    Nov 2009
    Karachi, Pakistan
    054.003 & 5.21
    Bro I did'nt upgrade it... i formatted the whole system then i installed window 7..Actually aero is'nt working on vista either... thats y..i cam to a conclusion that for aero i have to change the video card..
  8. #8
    TheRemco's Avatar
    Oct 2010
    1+1=2
    Samsung Galaxy S3
    what kind of video card do you have?
    and on my sisters pc, she does have a crappy graphic card, but you can install one from nvidia.com
    really it sounds weird but you can download a graphic card.
    try it
  9. #9
    Danial's Avatar
    Nov 2009
    Karachi, Pakistan
    054.003 & 5.21
    its builtin intel one
