Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
Thread: Sygic GPS Navigation (AURA) For Symbian^3
    Jun 2010
    Greece
    N95
    Default Re: Sygic GPS Navigation (AURA) For Symbian^3
    Quote Originally Posted by paparas View Post
    my friend the SygicDownloader_1.1 exe. on my pc download files for android and not for symbian 3..:-(if you want send me the settings of symbian folder.. i mean the sygic folder when i open ,has 3 folders auramaps, aurares, and symbian if you want help me i wiill wainting you....
    yes this pc downloader seems to be only for android. there is a new version 1.3 that has also symbian files
    May 2011
    Malaysia
    Nokia E7
    could you upload the installer to other file hosting.. maybe mediafire.. because, my country block putlocker.com
    f_p's Avatar
    Jan 2011
    ireland
    nokia n95 8gb, n8, n9
    Belle, Meego
    Jul 2011
    brasil
    nokia n8
    please maps do brasil
    --- Update ---
    o sygic install nao tem a opiçao mapas do brasil so portugal
    Nov 2010
    uk
    nokia n8
    na
    many thanksssss work fine on my nokia n8...........
    May 2011
    Malaysia
    Nokia E7
    work fine with my Nokia E7.. but no maps for Malaysia...
    Jul 2011
    brasil
    nokia n8
    o meu ta dando que tem que ativar, vai expirar 11-08-2011,alguem pode me ajudar como ativar,ja consegui os mapas do brasil,eu usei o programa que vei para o pc,e baixei pelo pc ficou joia. so preciso ativar
    Nov 2010
    brasil
    nokia n8
    fr-01
    Quote Originally Posted by dirce View Post
    cara acho melhor vc perguntar isso em ingles. usa o tradutor google pra escrever e depois cola aki. tb to com esse problema e to aguardando uma solucao. mas to contigo essa versao do sygic roda lisinho...
    Jul 2011
    brasil
    nokia n8
    ta my giving you have to activate, will expire 08/11/2011, can someone help me how to activate, already got the maps of Brazil, I used the program vei pc and downloaded the pc was jewelry. only need to activate
    Dec 2009
    Sammy's Galaxy S2, N8 & 5800 XM
    SGS2- Gingerbread 2.3.3 XWKF3, N8- Anna, 5800-V 52.0.007.C01.01 unhacked
    Online
    Can somebody tell the path where to place the map folder and base files!
    i've copied the maps and res folder in the root of memory card and rest as
    told above:
    sygic/symbian/core3d.ini
    sygic/symbian/KeyMap.ini
    sygic/symbian/settings.dat
    sygic/symbian/Settings.ini
    but app is not starting...
    please help![COLOR="Silver"]
