it still works only the 2.1 version on my i8910. what can i do to make it run?
how can i delete ... or uninstall the trial version completely? perhaps there are some files that didnt remove by the system using the normal way to uninstall.
Same here
I have missing icons in both v2.30 and v2.40 for my 5800
This is the bug fixed version of program... from İmmmoo's blog...
Code:http://blog.immmooo.com/download/MyPhone_5th_edition_signed.zip
By using this you can get back your "MYSETTiNGS" option... But there are some missing icons remains..
So next thing you have to do is;
- Open MYSETTiNGS
- Chose "set default"
- decide " are you sure or not"
- if you are sure say "yes"
Now you have all your icons... But where is my kiss?
to N97 owner, trial is start after step 2: overwriting with MyPhone v2.20. so you can not run mysettings. does anyone can help?
same problem with my n97 not hack because of v20 version of os
arg
only works with all icons up to v.2.20 on my Nokia 5800XM with latest v31 firmware - many thnaks for the upload
file uploaded to symbiantalk
1)Install MyPhone 2.10, run it once, also run once the MySettings, then exit.
2)Then keep overwriting with MyPhone v2.20 then with v2.30 then finally with v2.40 use this version http://www.symbiantalk.net/attachmen...9&d=1262971054
